03-08-2005 11:46 AM
03-09-2005 09:42 AM
04-12-2005 10:26 AM
08-01-2011 02:28 AM
The same problem occurs on my VI too. There is no error writing the data into .lvm, when I try to read it, it turns out NaN value or zeros.
I got only one value written to the .lvm file. When I try to read it, it gives out an array of zeros, or NaN values.
Here is a simple vi illustration;
There are several topics on this issue, there must be anyone to solve this problem, I guess and hope.
Ozgur
08-01-2011 03:00 AM
Interesting thing, when I recorded data with Headers, reading gave correct results. Try writing data with headers if you didn't.
12-11-2013 10:15 AM
This problem occurs when you attempt to read from the same file multiple times. The Express VI will not let you do this, unless you reset it in-between calls.
If you want to view different pieces of data from the same file, you should either perform the task manually with the File I/O pallette, or store the read data in a shift register and then use this whenever you want to re-read the data.
