We are trying to make a complete program to steer a test bench. We shall simulate a torque using a disc brake that is steered by hydraulic vents. The encoder will give the position, and turns. There will be no more than 20turns. To measure the torque we use a torque-measuring ring, and after 20turns a solenoid will stop the disc completely. The card that I choose AT-232/4 may not be the best to use? But 4 channels would be enough. 2 to read encoder and torque measuring disc 2 to steer the hydraulics for the brake and solenoid.
Are you looking for LV examples for serial? you can find them in, C:\Program Files\National Instruments\LabVIEW\examples\instr.
Some useful resources for your application are ni.com > NI Developer Zone > Development Library > Instrument Connectivity http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
