08-23-2011 08:55 AM
I have an oxygen detector with serial out
link to the owners manual with serial info
http://www.yokogawa.com/an/download/manual/IM11M10B01-01E.pdf
and I want to hook it up to my laptop to record the data but i am having trouble as my laptop has no serial port. so i bought this:
How do i read from the usb converter? I can program serial in with the visa on an old pc no problem, but this is giving me some trouble. Any advice would be appreciated thankyou.
08-23-2011 09:29 AM
08-23-2011 09:33 AM
And install the VISA driver 😉
08-23-2011 10:23 AM
I have installed all the drivers i think. I guess my problem is getting started. I don't know how to tell labview to look for a plugged in usb device. Normally with serial I just use the serial configure block and take it from there, but i can't seem to find one for usb, and it does not report anything back for the converter.
08-23-2011 10:29 AM
Does the new COM port show up in your PC's Device Manager? If not, you didn't install its drivers. If you see it, note the COM port number so you can set it in LabVIEW VISA. Beware, it could be assigned to any random COM port number and sometimes it MAY get re-assigned a new COM port after a reboot. This is not always the case but those USB to COM converters are a notorious source of trouble for many people.
08-23-2011 10:31 AM - edited 08-23-2011 10:32 AM
A serial port, even plugged through a serial-USB converter is usually seen just as a serial port.
So:
1) Find out with MAX the serial port name (e.g. "COM2"). Note: in the description of the serial port you may find some hint about it coming from a USB converter.
2) Use the VISA Vis as usual pointing to the serial port you have just found
Marco
08-23-2011 10:42 AM
Where would the number be? I am in the devices and printers section on the control panel on windows 7 and if i hit properties i can see this for the com name maybe? Port_#0004.Hub_#0005
08-23-2011 10:48 AM
I just ran the driver setup wizard in visa and got this error for the keyspan dongle.
08-23-2011 10:51 AM
No. You're looking for COMxx where xx is a number assigned to the port. I don't use Win7 but there must be a Device Manager. In WinXP it's right-click My Computer > Properties > Hardware > Device Manager > Ports. A Win7 user will have to help if that doesn't get you there.
As noted above, NI MAX also provides this info: Devices and Interfaces > Ports.
08-23-2011 10:55 AM
That might be bad news. My company actually assigned an engineer to buy every USB to COM converter he could find and test them all with as many apps as possible. There were many models that were problematic. You might need to just try another brand (or two (dozen!)).
Still, check the Device Manger or MAX just in case you get lucky...
