Read file with extension .wfv and display in the waveform graph
Hello, I have a file with the extension .wfv and I want to display these values in the waveform graph in LabVIEW. I think that this file has values from reading in the graph because the was generated in LabVIEW but I don't see the main program and was created in executable.
Regards.
(181 Views)
Hi Roger,
you need to know the format of that "WFV" file!
Once you know the format you can read the content correctly and display the data in a graph…
using LV2016/2019/2020 on Win8.1/10+cRIO
(112 Views)
