Is there any way to read data from serial port terminal window. This terminal window having lines and lines of value..Is it possible to read all the line and put in to text file or some....Please help me if you guys know the solution. Thanks in advance.
Thanks for the reply. Yes I know we can read directly from the serial port itself. But waht i want is is there any way to read terminal window(serial port) values...because am using one s/w which execute and display the results in terminal window...so I want get those values from the terminal window...u got what am saying?
There is no built-in mechanism in LabVIEW to do this. You can look to see if it can be done with operating system calls. I had previously posted an example on how to do it with the command window. I have no idea if it will work with your terminal window.
