Read data from CANcardXL useing LV8.20
Hallo everybody
I am trying to create a labview liberary to control the XL-CAN bus ( from Vector-informatik) functions under LV. and i'm useing the following HW/SW:
1- PCMCIA CANcard XL
2- CANcabs (Suports Low and High speed)
3- IOcab 8444opto (all hardware from vector-informatik)
4- Windows XP-SP2
5- Labview 8.20
6- CANcardXL driver v.5.6
7- XL-Driver liberary (API and .NET) version 5.7
MY problem(s):
I can not read any bus data (I mean neither CAN, LIN nor DAIO)  from the hardware, but set a configuration to the application (appName) and send data works fine. even by reading I dont get any error message or something (I get always XL_SUCCESS). I am trying to get this thing on the ball since more than one week but NO-WAY.
So is there any idea, tip or a small vi  example to read CAN data using .NET vector driver?
Any and all help appreciated
(4,172 Views)
it is fixed. the problem was the calling of the .NET functions sequence was wrong.
Thanks!
(4,147 Views)
Hello Amro,
I trying to communicate with a Vector CANcardXL using .NET too. I'm sending a request and receiving a response, but the received response is from the previous request.
What sequence did you finally use? I think I don't understand the sequence described in the API Description from Vector.
Thanks in advance!
(4,054 Views)
Hallo HoeS ,
sorry for lating replaying you.
in my VIs I used the sequence as descriped in the flowchart in the API-discription Manual.
befor I can figure your problem I need some more information.
1- what did you receive at the first Request?
2- did you set the receiving buffer size?
You may need to Flush your receivequeue using xlFlushReceiveQueue function at the first CAN-Request. so you make sure that your CAN-Hardware receiving buffer has NULL inside.
you may use xlsetNotification function, it helps you to fetch any Rx-msg just when it is on the bus.
I hope that I can help you fixing your problem.
(3,987 Views)
