06-03-2013 05:41 AM
Hi All,
I have a USB-6210 card which I would like to use for a PWM application and use one counter to write a PWM signal and the second counter to read a separate PWM signal. To test this I tried to to wire the output PWM signal to the and read it using the second counter. I have connected PFI4 (Pin6 - ctr0 out) to PFI3 (Pin4 - ctr1 in) but can't read the frequency or duty cycle, only managed to read number of counts. Any idea on how to correctly setup my DAQmx to read the frequency and duty cycle of the PWM out signal? Using LV2012.
Cheers!
David
07-01-2013
04:30 AM
- last edited on
03-17-2026
09:57 AM
by
Content Cleaner
Hi David,
The default PFI lines for the two counters in a USB 6210 overlap as explained in this article http://digital.ni.com/public.nsf/allkb/45E936F57132054D8625765E00577EB4 . You would therefore not be able to use both the counters on this hardware simultaneously.
Can you please upload your VI so that we get a better idea about what is going on in the code?
Thanks and Regards,
07-19-2019 09:18 PM
I am trying to setup a PWM using the DAQ assistant to control a servo motor but the assistant does not let me set it up as a continuous sample. It gives me error 200077. How did you set up your output PWM using the USB-6210?
09-30-2026 10:10 AM
I would recommend to start a new thread instead of adding to a 13 year old stale discussion. Also please explain exactly what you are doing, because controlling and sampling are two different things. Are you using any toolkits?
