Read an excel file and convert to a 1-D array of long, 32-bit integer?
Hi Guy,
any text editor can create csv files (as they are just simple text...)!
Anyway it should work with Excel too, everybody else uses those tool. Save your sheet in Excel as "csv", then close Excel. After that you can open the file in LabVIEW...
Message 11 of 20
(1,418 Views)
"Error 7 occurred at Open File+.vi:Open File"
I do appreciate you guys going through stupid things, because I'm pretty sure it's something stupid on my end. The file path is fine, I went into the properties of the file and found it there, so all I had to do was copy and paste that.
Message 12 of 20
(1,414 Views)
Hi Guy,
no need for "Copy&Paste" when you place a path control on the FP and use it's browse button...
Message 13 of 20
(1,409 Views)
Another trick is to drag the file itself into the file path control.
Error 7 is specifically that your file does not exist.  You are pointing to the wrong file or only the folder(?).
Message 14 of 20
(1,405 Views)
I've dragged and dropped, I've copy and pasted from the location in properties, I've browsed for path, and they all direct to that same location, so I doubt that I'm pointing to the wrong file. I'm not sure what else I can do to try and fix this.
Message 15 of 20
(1,401 Views)
Hi Guy,
can you open the CSV file with a text editor (Notepad will do...)? If yes, than LabVIEW should be able to open that file too.
Maybe a short peek into your VI would make sense? Mind to attach it?
Message 16 of 20
(1,404 Views)
I can open it with notepad.
I'll attach it. That column of numbers under the "read from spreadsheet file.vi" is what I was using before, and what's in the csv file that I'm using to test, in case you're wondering.
Message 17 of 20
(1,396 Views)
Hi Guy,
do you really think your RT target has access to your PC's harddrive? Those are two completely different computers.
You should have noted that in the first post!
Easy solution: Transfer the csv file to your RT target -  and don't forget to change the path according to your RT target file system...
Doh...
Message 18 of 20
(1,394 Views)
As you've probably figured out by now, I'm pretty new to all this, so I didn't think of anything along those lines.
Is transfering the csc file to the target as easy as dragging it under the target in the project?
Message 19 of 20
(1,383 Views)
No.  It's easy to do through Windows.  Run ftp://aaa.bbb.ccc.ddd (replace a.b.c.d with the IP address of your RT target).  Then drag the file to the appropriate directory on the RT target.
Message 20 of 20
(1,380 Views)
