Mark,
I haven't been able to find out if there is an ActiveX property or method the excel exposes to be able to do this ... searching on http://msdn.microsoft.com didn't return anything particularly useful.
I've tried this sort of thing a couple of different ways. The simplest is if I have control over the file generation code, in that case I've just used the first row A1 and B1 to contain the number or rows and columns respectively and moved on from there.
If that isn't a possibility then you could enter nonsense data around the acutal data and then look for that and then resize the array. This could get pretty slow if you read row by row, I've somtimes read chuncks of rows and then adjusted the next read and and combined arrays. With a large data set the memory and s
peed implications do need to be looked at.
The last thing is what you are referring to in 2. You should be able to save the .xls file as a comma delimited file. In this case the "Read for Spreadsheet File" vi should be able to just read all the data in. I'm not sure how easy it is to export an .xls file to a comma delimited format programatically.
I think this should work all though I haven't tried it. If it doesn't then you could just read one row and then count the number of commas to determine the number of columns. You can then read the entire file and convert the data into an array, as every comma would separate each column and a carriage return would seperate each row.
Haven't got LabVIEW on this machine so if I find anything new tomorrow I'll post again.
Kamran
