Read a particular column in excel spreadshee​t
Here is an example using the RGT in LV 2014. Please let me know if you have any questions.
Message 11 of 37
(2,283 Views)
Thanks greg,
Unfortantnly i dont have labview 2014. I have 2012. Is there a 2012 version of it?
Message 12 of 37
(2,278 Views)
I don't have 2012 to test with, but you can try this. I'll post the snippet as well so you can recreate it if you like.
Message 13 of 37
(2,275 Views)
hmmm, i believe im missing a widget. Since im recieving errors. When i open the VI, its going through the labview files. and asking me to open a missing file.
Message 14 of 37
(2,268 Views)
Do you know which VI? If you have the RGT then it's probably the read from spreadsheet VI, I received a warning that it may break when saving for 2012 or have the wrong polymorphic instance.
Message 15 of 37
(2,262 Views)
NI_Reportgenerationtoolkit.lvil:excel easy table(str).vi
Message 16 of 37
(2,254 Views)
And you do have the report generation toolkit?
Message 17 of 37
(2,248 Views)
No i dont.
Message 18 of 37
(2,245 Views)
Ok, then you may have to find a way to insert the values using ActiveX, but at least the conversions are already taken care of for you!
Message 19 of 37
(2,238 Views)
Currently what i did was i kept the time in a separate csv file and the numbers in another. then i opened them seperatly. so my program works but i just wanted to keep one file. I'm sure i have to play with the index array a little more.
Message 20 of 37
(2,235 Views)
