Read DCD on serial itf ?
Does anybody know how to read DCD on a serial interface using labview and
appropriate serial VIs ?
I'm using both NI serial PCI hardware and PC standard
Thanks for your help
(2,924 Views)
You can read the state of the modem lines using VISA and the property node.
(2,924 Views)
If by appropriate serial VIs, you mean VISA, then use a VISA property node. The property is Mdoem Line Settings>Line DCD State. I don't think it's available with the old serial driver.
(2,924 Views)
