@mikewitt wrote:
I am having a problem where I get the error "Error -229771 occurred at DAQmx Start Task.vi:1" with the information "Internal Software Error occurred in MIG software. Please contact National Instruments Support."
Now, from looking on the forums and in the knowledgebase, I have found that I can resolve this issue by clearing the MAX databse, with the instructions here: http://digital.ni.com/public.nsf/allkb/86256F0E001DA9FF86256FFD005B827C?OpenDocument
However, this is quite annoying, and happens on an almost daily basis--it happens EVERY time the computer is restarted. I only have one task, so I just delete the data folder and start again, I don't bother reverting to an older copy, but it's still quite cumbersome.
Does anyone have any ideas on how to keep this from happening again?
I am using LabView 2012 (32-bit) on a Windows 7 64-bit machine. I am also using a NI cDAQ-9174, with the first 2 bays populated with a NI 9205 and a NI 9401.
Thanks for any help you can provide,
Mike Witt
hi Mike,
i also encounter this problem, the internet address is invalid, could you tell me how you solve this?
Thank you!
