Re-naming all VIs in a project or library without breaking dependencies
I have a library that has several hundred VIs in it, with one top-level VI.
Each VI name has a suffix in it I would like to remove.
1.) Ideally I would like to write a script that changes the names so I don't have to do it one-by-one.
2.) Upon renaming I would like all dependencies within the library to be preserved
I'd also like to change the path and name of library itself without LabVIEW getting confused about where it's looking for various files. In particular I don't want it loading old versions of the VIs.
What is the best way to manage VI and library filenames?
(1,153 Views)
That's a lot of VIs for one library! This is a good application for scripting if you are up to it. Just make backups (obviously but you never know)
LabVIEW 2012
(1,147 Views)
Accepted by topic author caleyjag
Jim Kring has a utility which will do that:
http://lavag.org/topic/4810-openg-rename-folder-of-vis-utility-v16-released/
As long as you have your code is in memory (open the project), it will automatically link to the new files.
(1,144 Views)
This is a relatively easy task to automate using LabVIEW.
  1. Create a cluster whose first element is an I32 containing the number of items called by a VI and the second item is a VI reference.
  2. In your automation VI, open every VI in your library and populate the VI references in an array of the above clusters.
  3. Populate the number of items called by using Get VI Dependencies and using the number of items returned.  Make sure you query for the whole hierarchy.
  4. Sort the array
  5. Save the VIs to the new names using the array.  This will give you a bottom up save so everything will be correct.
This account is no longer active. Contact ShadesOfGray for current posts and information.
(1,143 Views)
