11-12-2018 01:29 PM
Hi friends
With help of my friend it makes this example.
Opinions are well come.
cpalka
11-12-2018 02:18 PM - edited 11-12-2018 02:21 PM
Hi cpalka,
did your friend tell you to hide ALL LABELS in the block diagram? NEVER EVER do so!
Why do you use shift registers in the way you do? Most of them could be replaced by direct wires:
I also replaced the FALSE constant at the while loop stop condition by a button: much easier to stop the VI.
I replaced the Mean ExpressVI by a simple Mean from the math palette: now you get a scalar value in a nice orange wire…
The feedback node after "Boolean" and the AND can be replace by PtByPt-BooleanCrossing function: much better documentation due to its help!
Your "booleans" should get better labels describing their purpose!
The two ExpressVIs in the snippet can easily be replaced by functions from SignalGeneration and array palette: see how far you get.
11-12-2018 02:46 PM - edited 11-12-2018 02:48 PM
Try to find better friends. This program is just plain silly.
Here's a very simple example that fits the earlier description to some extend, but modify as needed.
11-12-2018 03:03 PM
Hi altenbach and GerdW
Thanks for your suggest and advises, many thanks.
In my data file I will need a first column with time.
Normally I use the blue wire, my friend prefer orange wire, but it needs to have a Tick count time.
I normally use the blue wire.
With the example of altenbach I will make my project then I will post here the final example.
Cpalka
11-12-2018 03:31 PM
This is the first time you mention a data file. Is this now a different problem?
A blue wire is typically an integer. You have dynamic data wires, so call it that to avoid confusion. Dynamic data is very opaque because there is no way to tell what's in it from just looking at it. Could be single or multiple channels, numeric or boolean, etc. etc. You won't get errors if you connect them in a completely meaningless way. Most more advanced users stay far away from dynamic data)
Tick count outputs a blue U32 wire and represent a milliseconds counter that is completely random and useless. Only the difference between two tick counts has any useful meaning as long as it has not rolled over multiple times and the correct difference is still within the valid range.
Nothing is ever final. 😄
