04-04-2019 09:00 AM
Hi guys,
I am currently working on a project which i use cRIO 9064 as my PMU. Also, i am using op4510(opal RT) simulator to simulate my power system model. My simulator provides +-16V output voltage, and 15 mA(max) output current. Since I don't want to use current/voltage amplifier which is needed to use NI 9225 and NI 9227 analog voltage and current inputs respectively, i would like to use another analog input modules except both of these modules(NI 9225, NI 9227) for smaller measurement range. I would appreciate if you could give me some suggestions.
Thanks in advance.
Şamil
Solved! Go to Solution.
04-04-2019 09:02 AM
Hi guys,
Thanks in advance.
Şamil
04-04-2019 10:18 AM
04-11-2019 11:08 PM
Well, i did it unintentionally, sorry. Thanks for the reply 🙂
