Hi bhuvanesh,
no need to hijack very old threads…
i will get a subarray in integer format .
So your input data is already in some kind of integer datatype?
if i want to get that in double format array means what could i do ??
You could convert those integer data to DBL…
for eg 432.985 means , in integer it will round off and gives the answer but i need to get as it is in original array format ??
When you don't want to have integers then why did you read your array as integer? Read it as DBL right from the beginning!
pls provide the solution
Please provide examples of what your source data is, what VI you currently use and what is your desired output!
