12-29-2017 01:54 PM
Hello.
Pls, I want to plot contour maps from XYZ data that is already saved in Microsoft Excel as delimited spreadsheet VI.csv file. How do I apply the solution given below by Altenbach Knight of NI?
01-02-2018 09:19 AM
Hey EngrSadiq, I would suggest making a new forum post and referencing this one with a link. This forum post is from 2013, so you're more likely to get responses if you create a new one!
01-02-2018 10:34 AM
There is no solution below, but maybe there was one above earlier, before the post got moved to a new thread.
How is the data arranged in the csv file?
What's is the size of the xy area?
01-06-2018 09:16 AM
Hello sir.
Sorry, I was supposed to write earlier solution not solution below.
The data is separeted by comma, for all X and Y values. I have 3 rows and 169 columns. X ranges from -6 to 6 and Y also have the same range of -6 to 6. Attached is the copy of the whole data in Microsoft Excel as delimited spreadsheet VI.csv file. Thank you for your attention.
01-07-2018 12:31 AM
"Read from spreadsheet file" (or "read delimited spreadsheet" in newer LabVIEW version) will read your data into a 2D array. Use comma as delimiter.
Now you need to initialize a 2D array and replace elements with z data according to the xy indices.
2D arrays (or matrices) only have non-negative indices, so you need to offset the x and y to satisfy that constraint.
See how far you get. Let us know if you have more problems.
