Re: Reading a PWM and determining pulse width using a digital input pin on a NI 9425 DAQ
Have you been able to do it? I'm turning on a led with a Duty cycle of 70% and I'm also trying to sense this Duty cycle via DI.
Bu it seems not to work 😕 .
Any idea how to do it
(2,994 Views)
Hi Alex,
who is "you" you are talking to in your answer in this old thread?
Mind to attach your VI? What does not "work"?
(2,991 Views)
I attach the .vi, It read a Digital Input port conected to a LED powered with a PWM with a duty cycle of 70%.
I'm trying to read this duty cycle aprox, using only one DI, it should work but it's not even 20% accurate.
(2,983 Views)
Hi Alex,
can you attach your VI with some sample data?
Run the VI once, then set all values to default (in the edit menu). Then save the VI.
(And please don't save this single VI in a LLB, that's not needed nor recommended…)
Are you using a NI9245 module - or something different according to your VI icon?
(2,980 Views)
I can't read data, because I'm trying in DAQ-6251 and it says to use a port that supports buffered operations, but I only have the Port 1 and Port 0 available. With the port 0 it works, but i need to use the Port 1.
Waveform Characteristics (Port 0 Only)
PFI/Port 1/Port 2 Functionality Functionality
Static digital input, static digital output, timing input, timing output Timing output sources Many AI, AO, counter, DI, DO timing signals Debounce filter settings 90 ns, 5.12 μs, 2.56 ms, custom interval, disable; programmable high and low transitions; selectable per input .
Reference to the DAQ: http://www.ni.com/pdf/manuals/374566d.pdf
(2,974 Views)
Accepted by copyAlexRog
Hi Alex,
Then why did you hijack an old and unrelated thread?
Why don't you say so right from the beginning?
And why do you need to use port 1?
Why do you link to USB6341 when you use USB6251?
The manual is right: you need to use port 0 to read a digital waveform!
Why don't you use any of the PFI pins and a counter task to determine the PWM duty?
(2,970 Views)
