11-29-2017 09:11 AM
i have new problem.... two process in a whilee with diference times, when star the times collides. what do you recomend?
11-29-2017 09:19 AM
11-29-2017 09:26 AM
Hmm, I am not sure, but you mean that you want to sync two processes in two while loops? There are different options, with different "tightness" of sync. First of all, could you detail what are those "two process". One example: you can sync two DAQmx tasks with triggering, depending on your hardware...
11-29-2017 10:26 AM
I recommend to explain the problem in a few paragraphs and attach the VI that is giving you problems. Your current post makes no sense at all.
