08-02-2018 07:57 AM
Hello
I'm working on a project based on the example getting started 5783.
My problem is that when I compile by referring to the bitfile, the project works perfectly, but when I refer to the VI without changing anything, I have an error in the stream on the AO loop.
I tried to do some modifications in the FPGA VI and compile to have a new bitfile, the project don't work by refering the new bitfile.
It only works by referring the bitfile by default !
what can be the problem !
thanks
08-02-2018 08:03 AM - edited 08-02-2018 08:03 AM
Your message doesn't really seem to apply to the thread you posted into. I'm going to move this to its own thread so it gets the attention it deserves.
I suggest you attach some code so we can see what you are doing. It is very difficult to help someone debug a paragraph.
(Originally posted in https://forums.ni.com/t5/LabVIEW/FPGA-Array-of-I-O-References/m-p/3824562)
08-02-2018 08:11 AM
Thank you for your reply,
I have problems with the references,
For example, I'm working on the NI 5783 Getting Started example that can be found in the Labview Examples.
By default, when I open the project, the HOST VI makes refenreces through the bitfile, and it works very well.
Me, I modified the FPGA VI and when I will refer to the new bitfile generated after the compilation or refer to the FPGA VI, the compilation on the HOST crashes and displays error.
08-02-2018 08:46 AM
Hello
I work with labview 2017, (RIO0, PXIe, 7975R) and (IO module, NI 5783)
My problem is that when I compile by referring to the initial bitfile (NI 5783 - Getting Started_7975R) , the project works perfectly, but when I refer to the new bitfile (NI5783-GettingSt_FPGATarget2_NI5783-GettingSt_J5i5XucqzsU) or the FPGA VI without changing anything, I have an error.
It only works by referring the bitfile by default (NI 5783 - Getting Started_7975R) !
