03-19-2019 03:15 AM - edited 03-19-2019 03:18 AM
I have to generate 6 PWMs. It is possible to use only one timer?. I have done this file but only 4 timers appeared, and I should like use 3 to other purposes. (Note: I can not post a new thread)
03-19-2019 07:32 AM
I only recently started using Counter/Timers (I'd been in the "analog" world up until recently), and really started to admire them. However, I think found that (a) most NI DAQ devices have "too few" Counter/Timers, and (b) some configuration require pairs of Counter/Timers (as I learned when I could create one pulse when/where I wanted it, could create a second as well, but if I wanted to control pulse frequency, width, and initial delay, this required a pair ... Sigh.
You might look at/for NI's 6602, which comes as a PXI or PCI board, and has 8 Counter/Timers. Maybe NI has something else out there ...
03-19-2019 11:40 AM
I'm guessing you may have an X-series board -- they have 4 user-programmable counters.
It sounds like you want 6 counters for generating PWM and another 3 counters for other purposes. Is that right?
Bob Schor's suggestion of a dedicated counter/timer board is a good one, but there's a newer generation version that improves on the 6602 in several different ways (bigger FIFO, hw-timed DIO support, finite pulse trains with only 1 counter, more flexible digital filtering, and more). Check out the PCIe 6612 (also available in PXIe).
If you need to sync the 6612 counters with the X-series board you already seem to have, you should install a RTSI cable between them and configure MAX accordingly (so DAQmx can do auto-magical timing signal routing, once it knows they share a timing signal bus).
-Kevin P
03-19-2019 01:49 PM
Oooh, I want one ...
03-19-2019 02:20 PM
Oh yeah, one more big improvement -- buffered pulse train generation! (Something I had complained about / requested for about a decade worth of using the 6602. It came around with the STC3 chip in the X-series MIO boards, a couple years after I stopped doing apps that needed it.)
-Kevin P
03-22-2019 06:38 AM
I am programming a NI-USB-6341 that has 4 timers
I should like program several PWMs at the same frequency and other using different frequency and made following program:
[IMG]http://i65.tinypic.com/ogan4m.jpg[/IMG]
But I have to use the 4 timers to have only 4 PWMs.
Is there a possibility to use the same counter for several PWMs?
03-22-2019 08:12 AM
Same question you asked before and has been answered over here. I'll follow up in that original thread...
-Kevin P
03-22-2019 08:17 AM
General answer:
1 counter can be used to make no more than 1 output signal (some counter tasks use less than 1...). You cannot make 2 or more distinct output signals with 1 counter.
If you want several of those output signals to be *identical*, then you *might* be able to simply physically wire 1 single counter output signal to multiple destinations. Be aware that counters can only source a very minimal amount of current natively so there's no guarantee that 1 counter will drive several of your external thingies at once.
-Kevin P
