Re: Append data coming from Serial Port in Serial Indicator in Front Panel?
I am receiving an array by ZigBee interfaced with LabVIEW. The problem is LabVIEW receives the array of numbers if the largest index is 120 but if it is greater it receives nothing.here is my code.
(4,152 Views)
1. You should not have that FOR looop.  All it is doing is duplicating the data you recieved 1000 times.
2. What is the actual format of the data?  It looks to me that you are just not doing the conversion correctly.
(4,138 Views)
It is just an array of integers that I am sending.
I am facing two problems.
1. I am not receiving any kind of data if the array is bigger than 120 index size.
2.The second problem is that the number bigger than 255(1byte range) does not receive as it is ....like I got 255 if I send 300.....
(4,009 Views)
Hi, just two clarification questions because I'm not sure where the problem is exactly.
1. You mention an array bigger than 120 index. Where is the index larger than 120 indexes being generated? How do you know it has more than 120 items in the array?
2. I'm also not entirely sure what you mean by this. What string did you send, and what U8 did you receive?
(3,966 Views)
Clarification for the ist one is
I have simple array say 500 numbers of integer type.
If I set its index 120 then the other 380 element are rejected and I got 120 first elements
But if I set the index greater than 120 like 121,122.....
Then I received nothing.
(3,953 Views)
Could you upload code that reproduces this behavior that isn't using hardware? It sounds like the issue is within the software, so you should be able to recreate it and we can look at your code.
(3,934 Views)
