Re: Anyone know how I can convert a 1D array of 0's and 1's to a hex value?
On Wed, 18 Jul 2001 12:27:33 -0700 (PDT), in comp.lang.labview you wrote:
> Sergey,
> Wire your Byte Array of 1/0's to a 'Byte Array to String' VI
> [Functions > String > String/Array/Path Conversion palette], and
> finally send to a String indicator. On the Front Panel at the String
> Indicator, rt-click and set its Display to Hex.
> This works for me, but not sure if its truly what you looking for.
> Good Luck with it, Doug
Right, Doug.
Compare two result strings in attached vi.
Cheers,
[See first answer for additional information]
(2,576 Views)
[Attachment(s) for question]
(2,576 Views)
