Raspberry Pi: Failed to connect to the target
Hello friends,
                     I am using Raspberry Pi 2 B and LabVIEW 2020 Community Edition. I want to connect both of these using different procedures available online. But still, I am getting this error 'Failed to connect to the target'. For Raspberry Pi, I am using a 16 GB SD card with an installed OS with a Desktop version. I have gone through Tool>MakerHub>LINX>LINX Target Configuration and installed LabVIEW on Raspberry Pi (image 1). After installation, the Window showed my 'Installation Completed Successfully (image 2). But the installed version is not shown (image 2). Still, I proceed further and went to the example. When I run the code and tried to deploy it. It showed an error 'Failed to connect to the target' and connection failed (image 4). I could not deploy LabVIEW code to Raspberry Pi.
Can anyone help me to resolve this error? (Attached Images)
Hardware: Raspberry Pi 2 Model B vi:2
Software: LabVIEW 2020 Community Edition
(1,957 Views)
LabVIEW Community Edition only supports Raspberry Pi 3 or 4.
Getting Started with Raspberry Pi and LabVIEW Community Edition
https://tmesystems.net/
(1,941 Views)
Spoiler
On my Raspberry Pi board, it is written as 'Raspberry Pi 3 Model B Vi.2'.
Can you help me?
(1,924 Views)
It's so complicated that NI even has images you can plop on your RPI so you don't have to go through contortions to get it up and running.  Unfortunately I don't think they have one for 2020.  😞
Bill
CLD
(Mid-Level minion.)
(1,905 Views)
So, can you suggest the best combination of Raspberry Pi and LabVIEW that works efficiently?
(1,885 Views)
