Ramping an AC voltage from PCI6052E
Hi:
I have a PCI6052E board with SCB68 Acc.  I want to send in a AC voltage from 0 to 10 Volts, by ramping it from 0 to 10 Volts.  Also, I need to wait after each output for a fixed time. Does anybody have any experience with this?
Mizar.
(2,146 Views)
Where's Algor?Smiley Wink
(2,146 Views)
Hello Mizar,
There are many examples in LabVIEW that demonstrate how to program the PCI-6052E.  If you open NI Example finder and look under Hardware Input & Output >> DAQmx >> Analog Generation >> Voltage, you will find an example called Cont Gen Voltage Wfm-Int Clk.vi.  This VI demonstrates how to generate time varying signals in LabVIEW.
If you are just starting to program in LabVIEW with a data acquisition device you might want to look at this online knowledge base found here.
I hope this help.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(2,123 Views)
