Raised to power
how to calculate a.^2 in labview?
(1,595 Views)
how to calculate a.^p, where p is a fractional number?
(1,602 Views)
Accepted by topic author amandeepkaur
Search for "Power of X" primitive in Mathematics->Elementary & Special Functions->Exponential Functions
Lucian
CLA
(1,583 Views)
Spend 15 minutes looking at the Functions you see when you right-click a Block Diagram.  If you don't know what one does (for example, the one called "Square"), you can turn on "Context Help" (short-cut key is ^H), then if you hover over a function, a Help box will pop up.
While you are at it, you can expand some of the other sets of functions other than "Programming" (such as "Mathematics") and spend another period of time learning.  One nice thing about LabVIEW is it just takes a few mouse clicks to put some functions on a Block Diagram, wire up a Control on their Input and an Indicator on their Output, and try them out to see if they do what you need.
(1,571 Views)
thank you so much
(1,509 Views)
