09-28-2017 04:32 PM
What is the differences between RT targets and Real time Applications? Where I use one and the other? I'm using a MyRIO
Solved! Go to Solution.
09-28-2017 05:02 PM
RT target is the device the application runs on. In your case the myRIO. The RT application is the software running on it.
Note that it is the controller part of a myRIO. Below that is the FPGA which has different code you write for it which is compiled into BIT files.
09-28-2017 06:09 PM
For example: I'm doing a controller in myRIO and I need to use MathScript for calculate some parameters. So that I put MathScript on real-time application for the calculation and I send it to FPGA where it is my controller. And RT-target, for what I use it?
09-28-2017 07:04 PM
I'm sorry, but I don't understand what you are trying to ask.
If you have code running on the myRIO controller, that code is called real-time code, and it is running on the myRIO which is a real-time target. The real-time code on that real-time controller can be programmed to talk to any code that you have deployed to the FPGA fabric as a Bitfile.
09-28-2017 07:16 PM
Ok now I get it, my confusion was due to my boss told me that the controller should be on FPGA but like you said before that the controller code could be programmed on Real-time target and it can interact with the code that I make on the FPGA.
09-28-2017 07:21 PM
Correct.
What may be causing the confusion and the way your boss said things that way is that many of the RIO's. I know the cRIO, I'm not as familiar with the myRIO, the FPGA is within the same physical pieces of hardware as the real-time controller, but they separate portions of the hardware that communicate directly with each other.
