ā11-13-2013 05:07 AM
I have developed several applications using the NI cRIO-9073 Integrated chassis. The applications work perfectly well in volatile mode (development), but when I come to deploy the the RT target as an executable the application does not work. Now, I ran the LabVIEW Real-Time 1 Solution application and the same problem occured, in this case, the USER1 LED came on then went off as if an error occured. I finally trapped an error around the shutdown stage, attached, funny thing is though the error code doe not make sense as I am not using the FPGA, running in scan mode, however, I could be missing something.
(Note: I have obviously modified the Real-Time 1 course solution to use my existing hardware)
Now this is where it gets puzzling, 3 years ago I did the old RT course, LabVIEW Real-Time Application Development, I have now run the solution for this course, on the same target as the RT1 solution and it works!!!
I have contacted NI support with no solution to this problem. In the meatime I have a NI cRIO-9704 on order and when it arrives I will try again.
I really need to know, however what is going on here, does anyone out there have any Ideas? have you experienced any similar problems?
Neil
ā11-13-2013 08:12 AM
Note to self - Include attachment...
Error Log
Status: TRUE
Code: -65589
Source: Shared Variable in Chamber Control.vi->RT Main.vi
This error or warning occurred while reading the following Shared Variable:
\\NI-cRIO9073-0180F3D1\Thermocouple Mod\Temperature-cRIO
\\localhost\Thermocouple Mod\Temperature-cRIO
Error -65589 occurred at an unidentified location
Possible reason(s):
CompactRIO: The FPGA VI you are running does not contain the DMA FIFOs that the RIO Scan Interface requires. Ensure that the modules under the Chassis item in the project match the modules in the chassis, and recompile the FPGA VI.
ā11-13-2013 10:48 AM
Any chance you can zip up your whole project and add it as an attachment, or even better, simplify it down to just enough code to cause the error and then attach that?
ā11-14-2013 03:28 AM
I have added an attachment, last time I tried this didn't work...
If you can see the attachment, this is the RT1 Solution modified to use my hardware.
ā11-14-2013 12:38 PM
Yes, you are running the FPGA in Scan Mode. On a cRIO, all IO is through the FPGA, so you are using the FPGA in Scan mode to read temperatures and set outputs. I have no experience with the Scan Engine and shared variables so unfortunately I can't help here, but search through the help and the NI web site. Maybe there's something you need to do in order to properly deploy the shared variables and scan engine as part of a compiled application.
