I am working on deploying a LabVIEW RT system and running into what seems to be a power up order problem.
If I power up the PXI system before the laptop that is connected to the chassis, it will not connect to LabVIEW. Max can wake it up, but I must power up the PXI chassis after the laptop to establish communications.
this happens with either a crossover cable or straight cable.
Is there a setting that I am missing?
does it work differently if I target an EXE on the PXI system?
Any help would be appreciated.
Stu
Stu
