06-10-2021 03:16 AM
Hi Fred,
One thing crossed my mind.
Are you sure that the USB device supports the baudrate of 921600 ?
What is the result, zero bytes, error ?
Kees
06-10-2021 03:26 AM
Hi Kees,
Yes it does. I've also tried to configure the baudrate on the sensor to 460800 to use a NI USB-485, still works with their USB converter but not with either with the NI-8433 or USB-485.
And the most annoying thing is I get zero bytes back when sending a command and no error so nothing really points towards something specifically wrong!
Fred
06-10-2021 03:38 AM
Fred,
The data-line swap is still an option to try.
To be more sure can you measure the signals with an oscilloscope and compare the working and non-working situation ?
Kees
