RS 422 @ 8Mbit/s is it possible with Labview FPGA??
I've to read and write data over an RS422 link at a rate of 8Mbit/s.
Do you think it's possible to implement RS422 @8Mbit/s with labview FPGA?
I know that I will have to make electrical adaptation to use RS422 signals with FPGA card.
Can the FPGA IP available on this website do this?
Thanks a lot
Julesjay
(2,857 Views)
Yes it's possible to implement this into FPGA, if you adapt the electrical signal.
You can found on the link below all information about this :
http://digital.ni.com/public.nsf/allkb/7ADB475DF68DAB518625713A0052799A?OpenDocument
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(2,827 Views)
Christophe wrote "Yes it's possible to implement this into FPGA, if you adapt the electrical signal."
Are you sure ?
Depending on if that spec is baud vs bit rate and the over-sampling implemented in most serial read logic, the FPGA may not be able to cycle fast enough.
Ben
(2,823 Views)
