08-15-2011 03:44 AM
I'm still having this problem and I was wondering if anyone has a solution for me.
I have a shaft rotating at about 600 RPM. I have an analog signal that jumps to 5 volts whenever 1 revolution has passed. I do not have a digital encoder setup for this.
I would like to be able to measure the position of the shaft in real time. Does anyone have a solution? I have attached my VI. In the bottom right hand corner i tried to start a for loop that will count time, but it's not working out for me.
08-15-2011 03:58 AM
You can't "measure" the position of the shaft, you just count rotations on each 5V pulse that comes in.
At 600rpm, one rotation is done in 100msec.
What position accuracy did you expect?
Do you expect to run your LV application at 10ms basis to have an estimated 1/10 turn accuracy?
I can't open your VI since I'm using LV 8.6
08-15-2011 04:03 AM
I'm already counting rotations.
I think i should be able to measure the position of the shaft based on previous data. If i could get a timer to work properly then i could find the real time.
attached is the vi in 8.6
08-15-2011 04:04 AM
i need to have it as accurate as possible - 1 degree would be amazing.
08-15-2011 04:13 AM
Did you made the math???
600rpm = 1 turn in 100msec
360° = 100msec
1° = 0.278 msec
Do you expect your PC to run at that interval
08-15-2011 04:19 AM
is that a problem?
08-15-2011 04:22 AM
@kramerfrog wrote:
is that a problem?
Like Rachel onces said in "Blade Runner" Of course it is!
08-15-2011 04:24 AM
okay, minus that issue - what about the VI. is it possible to measure the position? There are digital encoders that do this..why can't i do it with an analog device?
08-15-2011 04:35 AM
labview can sample things at 100khz...i don''t think this should be a problem. Also the file i posted, the simulated signal i think should be changed to 10000 HZ at 3000 samples.
08-15-2011 04:39 AM
and the signal should be 8.34 hz. - i uploaded the correct file here again.
