RGB statistics for 32-bit image
Hi friends, I am trying to get the RGB information of an image.I created a labview VI using vision assistant for this.
But the issue is that, although it draws histogram for all the three colors, it displays "Statistics"
(i.e. max min value,standard deviation etc.) for only red color and not for blue and green too.
What should i do in order to get statistics for all the three colors.
Best Wishes,
Automator
(3,054 Views)
Accepted by topic author Automator
Did you just drop an express VI created from vision assistant or did you create the VI yourself from the vision palette?
I suggest you do the latter and use this function :
If you have problems doing this, post the VI you came up with, it will be easier for people to help you 😉
Hope this helps
Epictetus
Antoine Chalons
(3,011 Views)
yeah..it worked.initally i had built the vi using vision assistant.
many thanks for your kind support.
regards,
automator
(3,008 Views)
