@LVLV wrote:
I need to copy/read contents of a MS Word template file (text/tables/images) and write/append it to another MS Word File.
Please provide me with an advise.....
The MS Word document format has never really
completely and officially been documented. There have been reverse
engineering attempts that are used by projects like Open Office and
others but the result is limited in several ways. That said even if the
format would be fully documented you would not want to deal with that
yourself as it is rather involved.
The only two solutions that are feasable IMHO without you having to
spend men years of development effort would be to either consider a
different format such as ASCII text only or use the paid Report
Generation Toolkit with Word interface that gives you access to the
Word document object hierarchy over Active X. There are supposedly some
more or less involved VIs floating around that do implement some Word
automation interface through Active X too, so that with some extra
effort you could maybe get away without paying for the Report
Generation Toolkit, but both of these aproaches will require you to
have Word installed on the computer you want to do the Word document
editing since the LabVIEW VIs simply use Active X to control the
installed Word engine.
Rolf Kalbermatter
Message Edited by rolfk on 04-05-2006 10:15 AM
