I had almost the same problem as you with the reports, and I couldn't find
any god way to solve the problem inside LV. My solution is to use ActiveX
to export the data to Excel or Word. The ActiveX interface in LV is simple
to use and there are some examples at the NI homepage how to use it. I also
create the graphs directly inside Excel instead of exporting them as a picture
from LW.
One other problem that I dint manage to solve is how to get a decent picture
file out of a graph in LV. You are writing about the gif and png format but
none of these is relay god if you want to include the picture in a document.
Both those formats are pixel built up and I would like to have a vector image
like the wmf format instead. The vector format is scal
able and has a bit
better quality. If you right click on a graph and select copy then paste
it into for example Word, you get some kind of object that is scalable and
nice locking but I newer figured out a way to do this by code. Maybe someone
else in the n.g. knows some thing about this.
