RE; Edit postion multicolumn listbox
HI, i have a new question that is: if i want to set the postion of the multicolumn list box ( what I mean is instead start from first row and first column , i want to start as third row and first column , how can I do , is it use edit postion of the inside the property node? 2. after that , I have a new value at that row( let say for the third row and first column) ,how I move to fourth row and first column? Thx William Lee
(2,431 Views)
Just a suggestion.
Open a front panel. Click help in the upper right side of the top tool bar. Select find examples. Select the search examples tab. Type listbox. You should find a vi called 'properties tutorial.vi' . If you run/study this you will understand how the properties node works for a listbox.
Hope this helps.
Message Edited by GovBob on 01-29-2009 10:25 PM
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,426 Views)
