01-20-2022 10:33 AM
Hello, I was wondering if anyone could help explain how to use the sine wave Pt By Pt VI to get the same sine wave as I would get from simply using the simulate signal for a sine wave. I used the "help" associated with this Pt By Pt VI but it doesn't really help with the time aspect, should I be wiring the iterations to this part? And my phase, freq, and amplitude would just be the same as I would have it using the simulate signal I presume?
Thanks in advance!
01-20-2022 11:12 AM
The function will follow the equation given in the help file.
01-20-2022 11:18 AM
Hi ashrimega,
Well, you may use the iterator of your loop: this will be the same as wiring a time with 1s intervals...
You should provide a time value more related to your "real world", like elapsed time since starting the loop!
