Quick-Drop "How to"
I feel almost silly for asking (as I've been using Quick Drop for more than a decade), but I can't find (or remember) the Quick drop for "Add Structure (such as a Case or While) "on top of" parallel wires and have the wires "pass through" the StructurQuickDrop Wire-Through Query.png
e, either as Shift Registers or Tunnels.  Here a picture of what I hope exists.  Note -- I know I could create a Cluster and do a Bundle/Unbundle with InPlace Element, but still I'm bugged that I can't find where/if this exists.
(2,498 Views)
Personally, I am mostly a "Slow dropper", but you might want to ask your question here instead.
(Not sure if it can be moved.).
In this case, wouldn't a single shift register with an array of six elements be more manageable anyway?
(2,492 Views)
Absolutely.  As it happened, as I started building the VI, I realized I needed several changes that got rid of most of the inputs,  I think I might have a working algorithm -- going to run it against a "manufactured" data set.  Plus I'll follow up with your other suggestion -- thanks.
(2,456 Views)
I'd do a QD, ctrl+i of an increment on all the wires. Then place the case (it will 'include' the wires). Then QD, ctrl+r to remove the increments.
(2,421 Views)
Aha!  @wiebe@CARYA came up with a much quicker way of doing the wiring than what I was doing (physically connecting wires "through" the Case) (I'm embarrassed that I didn't think of this myself), but it suggests that maybe the Quick Drop "Add Structure Around Existing Code" might not exist ...
(2,397 Views)
Others want this too:
Option to connect wires through a dropped structure on the diagram - NI Community
(ArrSee had the same solution)
Pretty sure this falls in the "how hard can it be? Oops, wasted a week" category though.
(2,390 Views)
