Hi Guoxiang:
I would suggest following the example for software trigger and I would use
the IMS in positive ion mode.
I also seem remember that when using more than one channel that they should
be juxtaposed, so you should be using channel 0 for the trigger and channel
1 for the signal.
Hope this helps,
Pete
"gxchem" wrote in message
news:df15148d.0204182159.3d09e9a1@posting.google.com...
> Hi,friends.
> I'm trying to use hardware trigger to trigger data aquistion from an
> ion mobility spectrometer (IMS) through a NI AT-MIO-16X card. It was
> working with digital trigger (digital A) and falling slope. But for
> some reasons (sorry I don't have time to explain the reasons:), we
> want to change it to hardware triggering.
> Well, you might
suggest me to follow example. Yes, I followed the one
> in vi.lib/analogin/analogin.llb/Aquire N Scans Analog Hardware
> Trig.vi. I wired the trigger to channel ACH0, and signal channel to
> ACH4,respectively (I configure the channel number on the control panel
> accordingly, too). The signal and trigger can be seen from the Run
> Test Panel. Trigger falls to 0.0 V from 5.0 V. I set the trigger level
> to 1.0V with falling slope. The IMS is running in negative mode, i.e.,
> the baseline of the signal is -0.2 V and the max peak height is -1.5 V
> (negative mode). However, I always get error code -10403 in the sub VI
> named AI trigger config.vi.
> Any nice suggestions will be appreciated. Thanks.
> GC
