12-12-2012 09:26 AM - edited 12-12-2012 09:38 AM
Hey folks,
Based on the posts I read in my search I'm expecting a little heckling regarding that fact that I'm not using versioning control etc, but I want to ask this anyway (and I'm not sure if versioning woud have helped because I only opened-edited-closed once so far)
Last friday, I took the framework of project A and started reqworking it (renaming things, repointing classes etc) so that it can be the framework for another project I'll call project B.
I really don't think I left the project open or anything, and I know I saved it off as project b (using save as, in a different location). However, when I went to open the project this morning, some strange things happened and it prompted me with that "recover vis that were open when labview was not closed properly" - I selected "compare vis" for one or two of the vis and long story short I ended up hitting cancel.
My question is simple- is this recovery information stored anywhere else if I change my mind and want to either do more comparisons or do a recover?
EDIT: TL;DR: If I were to mess up and click "cancel" instead of "recover" is there ay way to go back and recover or review the code differences afterwards?
thanks
-pat
12-13-2012 05:59 PM
Hi Pat,
I haven't been able to turn over anything identifying if/where that information is stored. Unfortunately, I think you may have lost your chance when you hit cancel.
12-14-2012 08:06 AM
Thx for the response- I ended up scrapping the new project and starting over- seems to be going ok this time around
-pat
