[QMH] Having a state repeat until a condition is met (without blocking)
Highlighted
So, you're saying that, instead of queuing ALL 5 states at the same time, to just queue the first 3, then have the "3rd state case" set the queue to the next 2 cases?  At this point, am I just using a shift register instead of the message handling VIs?
I know I might be asking a lot, but if you could, could you make a quick example VI?  I'm not sure I'm making the same conclusions that you are.
Thanks Cross!
Message 11 of 13
(176 Views)
Here is a snippet and VI saved in 8.0 that you can mess around with.
Message 12 of 13
(163 Views)
OK, it looks like I was understanding you correctly.  Thanks for clarifying.
Message 13 of 13
(139 Views)
