QD: Alphabetize Case Structure Cases
Hello everyone
I have great interest in this issue too. Could someone save the file Alphabetize Case Structure.vi into 8.6 version?
Dan07
Message 21 of 23
(635 Views)
I've attached Alphabetize Case Structure.vi converted to 8.6.
Message 22 of 23
(618 Views)
Just wanted to let Greg know that I was able to use his QD shortcut for its original purpose. I've been put in charge of refactoring a massive program. The main VI has a very large case structure with >100 cases in it.
The eventual goal is to swap everything over to object-oriented code, but in the meantime, I was trying to sort all the cases alphabetically for ease of finding things. Trying to use the built-in "Sort" button in LabVIEW failed: no errors, but nothing would happen. I'm guessing nobody tried it on such a large case structure or in such a large/complex single VI?
The QuickDrop plugin, on the other hand, worked like a charm. So thanks for that.
Message 23 of 23
(455 Views)
