Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
06-15-2009 11:07 PM
Do you have your VI done yet?If so, press 'Tools' >> 'Web Publishing Tool'
A wizard will popup and walk you through the step-by-step process.
Please try this and come back if you have any questions afterwards.
We cant help you out until we find out where you are getting stuck.
06-16-2009 03:20 AM
I have done it many times but when i go to the site i want, it didn't appear the front panel or anything else.
What i do is
Tools-> options-> web server: configuration-> ip address of listener-> xxx.xxx.xxx.xxx/"name"
Is there anything else?
06-17-2009 09:15 AM
Hi d_nikolaos,
Did you try going to Tools»Web Publishing Tool as cork_k suggested? There is a wizard there to step you through the entire process.
06-18-2009 07:37 AM
It was the first think that i tried. But I thought that this only works in a local network.
Then I tried again but i didn't manage to do it.
Thanks!
We'll be in touch soon!
