i want to pulse a Keithley 2602A with LabVIEW. I got an example program where voltage pulses are generated and buffered.
Now i want to change this example program so that it generates current pulses and buffers them. I found a fitting VI wich generates these current pulses (called PULSEI) and my idea was to replace the PULSEV VI with the PULSEI VI. The problem is that the PULSEI VI has no terminal where i can buffer the data.
When i run my LabVIEW script the SMU shows the Error Code 5038: Index exceeds maximus reading.
Has anyone of you and Idea how to fix this problem? Or isn't it possible to buffer the data of an current pulsed Keithley 2602A at all?
Thany you in advance!
monuzw
