You can run applicaiton(.exe) file on a computer without labview as long as that computer has LabVIEW Run-Time engine installed on it.
You can install it through this link : Labview
To create an application (.exe) file, first you need to include whatever component you want to run inside the .exe file. You can follow either of these steps to create you .exe file.
1.
- Open the project window.
- Right click on the my computer.
- Add -> folder (Snapshot).
- Go to C -> Program files-> National instruments-> labVIEW 2011-> vi.lib-> Utility->open LVClass -> press current folder
- Repeat the same procedure for NIReport.lib.
2.
create these files follow the instruction shown below.
- Right click on the builds specification.
- Click on the New then Application (EXE).
- Before creating installer ensure the following that in the destination directory we need to mention two paths namely for .exe file & for support directory.
- Support directory having the path of database file.
- In all the VIs the path of database is same as installer file.
- So here both path should be same as shown below
- Enter the required input & create the .exe file
You can then upload the .exe file on to the website you wish to share.
Hope this helps
Fiona, NI
