11-14-2006 09:57 AM
11-14-2006 10:20 AM - edited 11-14-2006 10:20 AM
Message Edited by David Crawford on 11-14-2006 04:20 PM
11-14-2006 10:26 AM
11-14-2006 11:38 AM
Thanks for the responde David...
Dennis, I had used the 'Path/String Converter' like you have but I didn't know to use the 'Search and Replace String'. My Property Node was also not inside the 'For Loop' and I didn't have any of the 'Boolean' or 'Loop Iterations' connected to it. I'll mess around with the legend positioning and I'll check out the values from moving it all around.
Once again, many thanks (and probably more to come)
PS - "This is getting to be a habit...." - I figure I'd ask because it seems to come so easily and naturally to you, hope I'm not too much of a burden.
