Indexing an Array's individual elements is easy with a For loop; however, setting individual Properties for each element is impossible by the fact that all array elements are geared to have similar properties (such as Colors, Labels, etc.).
Clusters, on the other hand, readily allow varying properties for individual elements, however prgrammically indexing each element via an auto-index routine is virtually impossible.
With this said, I'll attach a LV6 VI (see answers with my VI) showing a manual way of taking an array of properites and matching them with an array (turned into cluster) of elements.
However, I am looking for efficiency in code, and have not yet found the right mixture of re
ferences, arrays, and clusters to set such properties.
I have studied many of the ideas presented here at the DV, but nothing exact that captures all I've mentioned.
Any ideas how to smartly implement property functions using auto-indexing routines for arrays/clusters as I mention??
Thanks for any thoughts and appreciate any examples (or words) which you can share,
Doug
