Project looses its files
hello Ed,
Thanks for the explanation. I mark this issue as resolved although I disagree that this behavior is expected and thus not resolved if you ask me. Let me argue once more:
The project file (.lvproj) clearly holds and maintains information that a particular folder, which used to be an auto-populating folder but which  LV converts to virtual (and empty) .  And the only reason for this behaviour is that a non existing folder cannot be an auto-populating folder - this makes sense.
But if the folder is recreated LV should switch back to its original state of an auto-populating folder - all the necessary information to do this is in the lvproj file. Information which the user put in there.
I don't see any reason why LV should not behave the same way both when reopening the project - re- populate whatever was in the folder and switch to auto given the occasion of a re-appearing folder.
Basically LV takes a decision to change the project folder structure without asking the user.
It is this asymmetry of functionality - sometimes it repopulates some times not - which is inconsistent and which probably is the cause of the quirk that the project looses files now and then. Although this last bit and my original concern, remains not clarified 100%
Message 21 of 21
(827 Views)
