Programming optical power meter 1931 c on labview.
Hallo all who read this thread,
I am trying to program newport optical power meter 1936-c in Labview but could not communicate with the instrument over USB connection.
I have installed the drivers necessary for the operation of the optical power meter from newport website:
ftp://download.newport.com/Photonics/Power%20Meter​s/x936-C_x1928-C_1918-C_R_%20Software_Suite/
I am running windows XP service pack3, 32 bit version.I believe I have installed the correct version of the driver for communication with the device over USB connection.The application software provided by the newport runs correctly, and I am sending and receiving the commands,but when I try to connect to the power meter using Labview sample programs provided by newport, I am not able to send or receive anything,instead the program seems to run an infinite loop and i get no reply until I have to restart the program.I am using Labview service pack 9 and I have tried all the sample programs 7.x ,8.x and 2009 version provided by newport ,but unfortunately no progress(:
I am trying to send a power command PM:power?(no smiley) to the power meter to get the power.But it doesnot give anything.
For this puspose I have found somewhere on the forum this file: NP_GeneralDrivers_LV8.llb (file attached).I have used sample query program with this file but still the device is not responding .I dont know how to proceed now, as I have only basic knowledge of Labview programming.
I have attached some screenshots of the program I am currently using:
I would highly appreciate if someone could help me.
kind regards,
shami
Message 21 of 23
(1,021 Views)
Hi Shami,
It looks like there are several custom made VIs in Newport's shipping example. I would recommend contacting the manufacturer regarding this issue. Otherwise, I have included a few example and tutorial links below on VISA USB communication with LabVIEW. Hopefully, this is a good lead on you.
6 Things you need to know about USB Instrument Control
http://zone.ni.com/devzone/cda/tut/p/id/4878
USB Instrument Control Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/4478
USB RAW Instrument Control Example
http://zone.ni.com/devzone/cda/epd/p/id/3637
Josh L.
Message 22 of 23
(987 Views)
Hi Josh,
thanks for sharing the links.I will follow the tutorials soon.Hope I could find a solution to my problem.
Kind Regards,
shami
Message 23 of 23
(979 Views)
