Programmatically change the y-axis name on a second y-axis
Hello, I have mixed signal graph on which I am plotting two signals.  I have created a second y-axis, so that I have one on the left and right side of the graph.  I am interested in naming the y-axis on both, and have been successful in naming only the RH one using the YScale.NameLbl.Text property.  How do I control the LH side?
Thanks!
(4,105 Views)
Accepted by topic author Eric_Lang
You are in the right area, there is a property node for this, I think you have to set the active Y scale first then set the property. Sorry I don't have the code I did this on handy at the moment.  It seemed that using the property node from top down, I would input the axis, then change properties, then input another axis, change properties, and so on ( I did the x-axis as well as both Y's.).
Mark Ramsdale
(4,104 Views)
That did it - thanks!
(4,100 Views)
